Seite 1 von 1
Hello, I need engine for T3
Verfasst: 14.06.2010, 20:54
von mojopiconT3
Hello, I'm new here.
I'm from Spain.
I'm looking for an engine for my van VW Transporter Caravelle, of year 1986, petrol, 1.9 liters.
The engine type is 2-DG-2S (with carburetor).
Do you know where I can find this motor?
where I can get it?
How much it cost?
Thanks and best regards from Spain!
Re: Hello, I need engine for T3
Verfasst: 14.06.2010, 21:41
von Atlantik90
Do You want it refurbished or a used one in undefined but running condition?
I wish you good luck in finding. I have none.
Verfasst: 14.06.2010, 23:29
von Atlantik90
here is an example, wher you will find what you are looking for:
http://www.motoren-seidl.de/motoren.html" onclick="window.open(this.href);return false;
VW T3 1900 cm³ Benziner wassergekühlt 57 kw DG teilüberholt 1350,- Schwungscheibe mit eingestelltem Axialspiel ist dabei
DG-Motor partly refurbished with flywheel included (axial tolerance set)
Verfasst: 15.06.2010, 00:43
von mojopiconT3
Thanks neujoker!
Just what I'm looking for!
do you know others like that?
Verfasst: 15.06.2010, 12:49
von mojopiconT3
neujoker hat geschrieben:here is an example, wher you will find what you are looking for:
Hello neujoker,
yes I'm looking for something like that,
I'm tryng to find my engine in Germany, mainly in Stuttgart, and in the area around Stuttgart. Also in the area near the border with France.
Do you know anything else in that area?
Best Regards!
Verfasst: 28.12.2010, 10:44
von jo928
como paso tanto tiempo, ya encontrastes un motor ? si no tengo varios y me voy a bajar entre pocos dias a valencia . si necesitas algo mandame un mensaje a 654841144 saludos jorge
Verfasst: 02.01.2011, 20:24
von puffin
Kann das mal jemand in die Spanish-Corner verschieben..
Verfasst: 07.06.2012, 13:55
von Horny
Hello T3 friends. I need an advice and help. My engine is broken 1.6 td jx, cylinderhead has cracks everywhere and two cylinders are scratched. I'm looking for refurbished engine. Which company can you recommend? If possible, somewhere close to Benelux.
Thanks
