Reverse Light Switch position?
this subforum is dedicated to our dear english-speaking vw-bus-drivers... feel free to ask, mention, and contribute on all topics regarding vw vans!
Moderatoren: jany, Staff
Krillo
Aufbauart/Ausstattung: Bus
Leistung: 78 PS
Motorkennbuchstabe: DG
Beitrag von Krillo »
Hi all,
My reverselights do not function. I've looked through the documentation but can't find where the switch is located. If anyone has a pic or a document, that would be greatly appreciated!
Thanks
CBSnake
Motorkennbuchstabe: MJ
Re: Reverse Light Switch position?
Beitrag von CBSnake »
on the left side, of the gearbox. Or better: across the Point where your Gearstick goes into the gearbox
Or do you have Automatic Transmission?
Greetings
Bild mit Autogas
Krillo
Leistung: 78 PS
CBSnake hat geschrieben: 30.05.2023, 19:22 Hi,
Greetings
It's a manual. Thanks, will have a look at it today!
best regards
/K
Krillo
Leistung: 78 PS
One of the connectors had come loose.
Cleaned the contacts with steel wool and contact cleaner, then connected them.
Works no problem :-)
That was a quick and easy fix, thanks again!
/K
Zurück zu „English-Corner“
